20 Most Recent
Samsung CLX-3305FW Color Laser Multifunction Printer Questions & Answers
How to clean waste toner tank
1st don't wear a new shirt when doing this !!!!
waste toner tanks are not meant to be reused (not saying you couldn't ) but its gonna make a mess doing it so id choose not to do iinside the office that's for sure , replacement tanks are available from same sources you buy toner cartridges from then just tape up the spout and toss old one away , some machines will require a manual reset of toner tank alarm , consult your manual to see how you do it
and if your dead set on cleaning it , what id do is buy one new one install it and take old one outside in a field miles from nowhere using 91% isopropanol alcohol and a hand full of old rags (disposable gloves too) id wipe it clean ,then store it under machine in paper storage box (not tray) so its there ready to use next time you need it
9/17/2015 10:13:07 PM •
Samsung...
Answered
on Sep 17, 2015
Samsung CLX-3305FW Imaging Unit error
Insufficient information to answer the problem. Try going directly to their web site http://www.samsung.com/us/search/espsearch.us?keyword=CLX-3305FW+ and check the SUPPORT and FREQUENTLY ASKED QUESTIONS section
5/4/2014 5:32:21 AM •
Samsung...
Answered
on May 04, 2014
How to connect printer to iMac
Go to System Preferences--> Print & Fax-->Under Printers click the + button and add the printer to your queue
8/4/2013 5:15:52 PM •
Samsung...
Answered
on Aug 04, 2013
I have a samsung C410W printer which keeps on flashing red and will not print. Help
Samsung printer C410W. Red light flashing.Checked paper paths; checked cartridges (nothing lower than 85%); removed and returned cartridges; checked back panel paper path. Still flashing red.
Technician's Assistant: Have you tried running your printer's self-cleaning cycle? (Sometimes you have to run this several times to see results.)
Is the self-cleaning prompt in the Easy Printer Manager?
Technician's Assistant: Have you tried wiping down the metal contacts on your printer and cartridges?
I have now wiped them
Technician's Assistant: Anything else you want the Printer Expert to know before I connect you?
How do I start the self-cleaning cycle?
I can't show ip address of printer samsung ml3312nd
In Windows, you can use the Control Panel to find the printer's IP address.
- Go to Settings > Devices > Printers and Scanners.
- Find your printer in the list, click on it, and select Manage.
- Click on Printer Properties.
- In the General tab, find the Location field. Your printer's IP address will be located in it.
For MAC OS click the Apple sign and locate printers.
