20 Most Recent Waring 6001 Commercial Juice Extractor Questions & Answers
2answers
I need manual to learn how to use it
If you Google your query you will be able to find the manufacturer, they should be able to help you with a manual for this model. I hope this is of some help.
10/16/2019 3:40:37 AM • Waring 6001... • Answered on Oct 16, 2019
Screw for my Waring PJE50 juicer to hold shredding disk
Try this link, sorry only just saw your message
http://www.nisbets.co.uk/products/ProductList.asp?TopGroupCode=C14&ParentGroupCode=S312&GroupCode=5573&page=3&ppc=
1/7/2010 5:28:20 PM • Waring 6001... • Answered on Jan 07, 2010
2answers
Help I've lost the screw for the juicer plate
goto http://www.thegourmetdepotco.com
part number:
Waring Juicer Clutch
Item #501238
Plastic clutch for shredder plate
7/20/2009 3:14:10 AM • Waring 6001... • Answered on Jul 20, 2009
Waring jex 328 healthjuicer does not work
Does it not turn on at all? Almost a year has gone by since you asked!
11/26/2014 1:45:48 AM • Waring Juicers • Answered on Nov 26, 2014
Juicer is too loud
I have a waring juicer and yes it is loud. Too late for an answer!
11/26/2014 1:44:11 AM • Waring Juicers • Answered on Nov 26, 2014
Loud "pop" noise as if
The reset button is actually a circuit breaker in miniature but there may be a thermal fuse to protect against fire in case of failure of the circuit breaker.
If you are game, open the housing again and look for a device you don't recognize that is in series (in line) with a wire; it may be in an insulating sleeve and not immediately visible, appearing only as a thickening of the wire. This could be a thermal fuse.
They are not supposed to open under load but only when the temperature exceeds a limit and these do not reset. Unfortunately, these are now all coming from China and are not very reliable so may open even when the design temperature is not exceeded.
If concealed, you would need a simple multimeter to determine if it had 'opened' by checking for the continuity of the wire stretch.
Blenders in general are 'universal' motors which can use AC or DC and this type employs carbon brushes which do abrade with time and when they have become too short, they can become intermittent and cause such a popping sound too. Brushes are replaceable so you might check Waring's website to see if they offer a fixed-price replacement or brushes as replacement parts.
I would be prone to see the Waring restored since most replacement blenders are from China and have often more than just one problem even when new. One given to us as a present smoked while crushing ice so we retrieved our old Oster from its stash and tossed the oriental wonder.
1/9/2011 7:42:43 PM • Waring Juicers • Answered on Jan 09, 2011
Cord was burned, need it
the cord is a standard AC cord -- you should be able to find a standard 3 wire AC cord at your local hardware store and wire it to the juicer,, just be sure to label and take note to wire color and location on the juicer.
c...
1/3/2011 1:28:53 AM • Waring Juicers • Answered on Jan 03, 2011
Juicer Jar defective with leakage problem.
Question edited for clarity. Question moved from Computers to Juicers. 3 Duplicates deleted. Refresh the page to see your question. Just contact Amazon and Return it. Log into your Account, click Orders, Find that Item, click Return, it will ask why? Tell them it leaked and set on fire when you used it for the fist time!
Returns and Refunds - Amazon Customer Service
Amazon.ca https://www.amazon.ca > help > customer > display Spotlight · Need to Return Something? · Return items using the Online Returns Centre. · Image linking to self service return video · Returns Items You Ordered.
Return Items You Ordered
Return Items You Ordered · To display your recent orders go to ...
Returns
Returns. If you need to return or replace an item, visit Your ...
Amazon Refund Timelines
We typically process returns within two weeks after the carrier ...
Track Your Return
Track Your Return · Go to Your Orders. · Select View Return ... ..
12/12/2023 4:35:05 AM • Juicers • Answered on Dec 12, 2023
I have a singer juice giant model 774 and I cannot
General instructions: clean the basket-filter-screening of your Singer Juice Giant Model 774: First, unplug the juicer from the power source and disassemble it. Remove the pulp container and the juice jug. Locate the basket-filter-screening and gently twist it counterclockwise to remove it from the juicer. Rinse the basket-filter-screening under running water to remove any pulp or debris. Use a soft-bristled brush to scrub away any remaining residue. Rinse the basket-filter-screening again and dry it with a clean towel. Reassemble the juicer. If you need more detailed instructions, you can refer to the manual for your product
10/31/2023 4:30:58 AM • Juicers • Answered on Oct 31, 2023
Jack LaLanne Juicer. The center screen adaptor doe not loosen and caused motor to lock up.
Questions edited for all the typos and spelling errors.
Contact
Jack LaLanne https://jacklalanne.com > contact Contact. June 8, 2016 admin. Your Name (required). Your Email (required). Subject. Your Message. Sending ... 785 Quintana Rd, Morro Bay, Ca, 93442.
Contact Jack LaLannes Power Juicer Customer Service
Consumer https://jack-lalannes-power-juicer.pissedconsumer.com > ... (973) 575-5400. Sales/ Reservations: (973) 287-5150. Spare Parts Order. Send Message.
Jack Lalanne Power Juicer Customer Service Number
addresscustomerservicecenternumber.com https://addresscustomerservicecenternumber.com > 18... Dec 1, 2016 - The customer service number of Jack Lalanne Power Juicer is : +1 (973) 287-5150. For other related queries, suggestions and feedback, you can ...
10/25/2023 6:11:24 PM • Juicers • Answered on Oct 25, 2023
Waring 6001 Commercial Juice Extractor Logo
9 questions posted
Top Waring Juicers Experts
ADMIN Andrew
ADMIN Andrew
Aron
Are you a Waring Juicer Expert? Answer questions, earn points and help others
View Most Popular
Waring Juicers
  • Waring Juicers
Most Popular Question
help ve lost screw juicer plate
  • Juicers
